Power Windows/ Locks
Guest Riggs
i dont know if this is the right place but i have a deliema.
alright i have a 92 body, with No power windows and locks. and i have a 90 silverado that a local kid rolled over and bought from him. that HAS power windows and locks, they are the same body style everything i have the inside of the doors, switches, faceplates, everything. how hard of a task is this to switch all of this so i can have power windows and locks in my truck?
and 1 more thing does anybody know a place that you can get that rubber inside your front wheel wells that is made for a 3 in body lift because there is a big space inbetween because it doesnt reach down far enough now.
i dont know if this is the right place but i have a deliema.alright i have a 92 body, with No power windows and locks. and i have a 90 silverado that a local kid rolled over and bought from him. that HAS power windows and locks, they are the same body style everything i have the inside of the doors, switches, faceplates, everything. how hard of a task is this to switch all of this so i can have power windows and locks in my truck?
Swapping the inner door panels is no biggie. The regulators and handles,etc all mount to the inner removable panel in the door. You can use wiring harnesses from the donor doors which should plug in. You'll likely need a relay or two to swap into your truck as well. Shouldn't be too hard once you swap the wiring harnesses for the doors intou your truck.
With two trucks next to each other the job should be relatively simple...
Those gap guards you are looking for are readily available through anybody that does or sells lifts.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,164 Guests (See full list)
