Missing Out Between 1k And 2k
I have a 99 sierra with the 4.3 V6
The engine misses out between 1k and 2k rpms. It does it in neutral and while driving. I replaced the fuel filter then the throttle positions sensor and it still does it. I also cleaned the MAF sensor with MAF cleaner and still no change. Can anyone help.
IDK if this is the case, but if you changed the exhaust on the truck to one with a larger diameter, you may have lost enough backpressure to have made a difference. As I said earlier, I don't know if that is the problem, since I haven't ridden in a truck with a cat-back exhaust system (that I know of), but that may be the problem.
Yes, the truck does have a new exhaust from the cat to the back including a new muffler, I'm not sure of the size so ill have to measure it today. If it is too large, what can be done to restrict it.
Could be an injector,spark plug, or spark plug wire. Check it at night in darkness to make sure you are not arching. Injectors you can feel the pulse.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
