A Spin On The Thread That Got Me Here
SnakeEyeSS
Which brand of TP do you prefer?
47 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Let's ring in the New Year with some humor
It was a odd poll that got me started here long ago the "which way do you prefer the toilet paper roll to face" thread. may it RIP.
Who remembers the old Cottonelle Ripples commerical:
"ripples means a cleaner bottom, and I'm the only one that's got'em!"
Where did this come from?
Well, married for alomost a half year now, we recently hit the household debate over which BRAND OF TOLIET PAPER?
I was a C-Ultra Soft, but the C-Ultra Strong is nearly as soft and lasts MUCH longer.
I'm gonna have to go with Quilted Northern. But my mom's a hippie, and buys the all natural stuff. Sometimes it still has chunks of wood in it... :dunno:
i go for whatever is the cheapest ... it is just gonna end up full of s**t and flushed down the tube before ya know it anyways...
That means that it's time to buy your own stuff. Wood chunks don't belong anywhere in that area.
I think we use that "with chunks of wood still in it" stuff at work. I try to avoid going at work, but some times you just have to... Regardless, at home, I go easy on myself... Charmin Ultra Soft. I don't care if it is more expensive. I'm worth it! hehe! :dunno:
Really man? I find it pretty hard to go on myself... even at home! :(
...Sorry man, I could not for the life of me resist that one! :nopity:
I don't do the toilet paper buying for the household, but Cottonelle is what we use.
Really man? I find it pretty hard to go on myself... even at home! :D
HAHAHAA!! That was pretty good! I guess I did leave the door open for that one.
Note To Self : Re-read posts more thoroughly.. :(
Charmin is a toilet clogger. But sometimes after 5-6 trips to the toilet from eating mexican and spicey food a water squirt gun does the trick........................................J/K
I usually pull out the old pillow cases on mexican night...... :nopity:
When I was in scouts, we had a guy go in an old outhouse that didn't have any TP in it. He came out, and found a pipe wrapped in some stuff. He tore a little off, and used it to clean himself up. Turns out that what he grabbed was a handful of fiberglass.
:nopity:
You've never seen a guy more uncomfortable hiking than he was that afternoon. We laughed about that for years.
A comedian (I can't remember who) once said "you're never too poor to buy cheap toilet paper!"
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,016 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
