Yukon Questions?
Searched through some threads and couldn't find a decent answer for what I'm thinking of doing. I have an 01' Yukon and plan on adding a winch. Q1. Would it be better to add a winch with a transformer type system or would replacing the bumper with a winch bumper (Ranch Hand Legend)be more effective for higher positioning? Q2. With either option I am concerned with front end sag from the additional weight. Would changing the torsion bars to the ones used on the 2500XL help alleviate this without having to significantly alter the suspension ie lifting?
If the 01's are anything like the 94/95 they sit a bit low in the back end already anyways. Just get someone thats about 200lb (or close to the weight of the winch if its more) to sit on the crossbrace above the radiator while you watch your suspension sag a bit.. if you dont like how far it goes down then either new keys or turning the stock ones 3-4 turns should be plenty.
Either way i dont think it will be enough to worry over.
    HWN808
    HWN808
  • Who's Online   6 Members, 0 Anonymous, 1,207 Guests (See full list)
