Brake Lights Staying On, No Right Turn Signal
I realize I don't have a GMT800 or GMT900 truck (I have a '98 K1500), but apparently a lot of GMT400 post threads in here and this is the most popular sub-forum, so I didn't think it'd hurt to ask. Anyway, here is the link to the thread describing my troubles. My right turn signal has gotten to where it won't blink (but will light up), but the left signal and hazards will work, and I even replaced the relay. Now, my brake lights are staying on all the time and won't go off even with all of the light related fuses pulled. Any ideas?
If the brake lights are on, you can check the switch under the brake pedal to make sure it is ok. The backing plates for the rear light assys were notoriously bad in the early 90's, but not sure if they had the problem fixed by 98. I would take a good look at both of them. Since you just bought the truck recently, I'd look around the rear bumper to see if the previous owner had some kind of hitch wiring that may be causing you grief. When you say you replaced the relay, did you mean flasher?
I am thinking its the turn signal switch. Brake lights, turn signals & 4 ways all go through the turn signal switch.
Unfortunately so does the wiper/washer and cruise controls. They call it the smart stick. When I replaced mine because my blinker would just start blinking for laughs, it was about $250 for part.
Guest chevydeerhunter
Haha! If it caused the blinker to start blinking for the hell of it, they should call it a Smart-a*$ stick!
Yes, I meant flasher. I have this same thread in the "Ask the GM Technician" subforum and they seem to think it's my trailer connection terminal as you thought. I'm going to take a look at that, next. Thanks for all that replied! If the trailer connection isn't the problem, I'll probably end up replacing the switch assembly. :lol:
***UPDATE***
Well, today I found that my left turn signal no longer worked, nor my right, nor my brake lights. Apparently the fuse blew, but I've replaced it and they're doing the same thing as they were before again. Does this tell me/you all anything? AND, I found that once I turn on the right turn signal (still not blinking) and turn it back off, the brake lights/turn signal lights are no longer on, but after doing my left, they stay on. This now makes me think that it might not a brake light related issue at all, just solely a problem with the turn signals (the brake and turn signal lights are the same lights, correct?), as proven by my discovery with the right turn signal. However, after turning off the right signal, my brake pedal failed to light up the brake lights. I'm still going to try to find the trailer connection wire/fuse and disconnect it to see if that's the problem, as it might be corroded, plus mine wasn't factory installed and I'm not quite sure where to find the fuse or the connection. If any one else has some ideas they think might be the problem, let me know! Thanks all!
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,260 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
