interested...what does everyone...
sunnydude
I work in education, K-8 school as a LAN Administrator / Help Desk. That's why I'm on the computer all day  :thumbs: ... lots of stuff to research.
bassdog
I'm a Machinist and Assembler for General Electric Transportation Division.  I build V-8, V-12 and V-16 diesel engines for locomotives...  (some engines are also used in tugboats and ferries while others are used as stationary power...)
I also have a bachelors degree in Computer Science with a minor in math (neither of which I'm using right now)
I am a business development manager for a publishing company... and my BA is in Elementary Education.. believe it or not, there actually was a logical progression from my degree to this job!  :thumbs:
I do AutoCAD drafting, also.  Working for a small architectural firm, I get to do some design too, but mostly just drafting the designs of others.  From remodelling to new construction, mostly schools and city offices, but a couple hi-end residential projectshave come thru.  Also do some network administration, although that is only because nobody else wants to.... I get a nice computer, with a good DSL connection, so the web is a nice distraction ;)
Im also in CADD.  I do PDS modeling, Microstation, and AutoCadd.  I work for a engineering firm in the power division.  I mostly use PDS to route ductbank and cable tray.  And also use Microstation for the 2d stuff.  Im a AutoCadd person at heart but there isnt enough work in this department to have me working in AutoCadd all the time.  But I like 3D so I dont mind using PDS.
I'm active duty military (Navy). Currently I'm Leading Petty Officer and an Instructor for the CV/CVN class ship Computer/Peripheral Maintenance course of instruction (main frame CPU's and related equipment).
In a previous life, I was a draftsman. I worked in '74 as a draftsman at a foundry. No such thing as Auto-Cad then. As a matter of fact, my chief engineer had the first hand-held calculator I had ever seen. It was a Hewlet-Packard that sold for 450 bucks. Couldn't sit at a desk and draw all day.
I assist in the destruction of foregin government property. :thumbs:   I'm an F-16 Weapons Loader in the USAF, currently working as the Weapons Academics Instructor for my base.
Wow what a mix of occupations :D
My turn:  I am a firefighter/EMT for a career fire department,
Local 998. In my spare time I do construction in the summer and ride my sled as much as possible in the winter. :thumbs:
I am currently a college student working towards a BS in Education, specialty Social Studies 5-12.
During the summer I go back to the job I had before I quit work and returned to school, Water Treament Plant Operator and water line/meter maintenance.
I also have a AAS in Criminal Justice that I will probably never use, unless I got into teaching in a correctional education facility.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
