Stall Converter
Got my Engine and tranny out the other day. Putting motor in with a mild cam rated around 280 hp and I have no idea on torque. Also getting the tranny rebuilt gonna cost me around 900 bucks. While i was at it was thinking about either putting a 2000 B&M stall converter with lock up or a 2400 stall with lock up. Cant make up my mind. Any suggestions?
If I knew more about the older motors/cams I'd help out, but I'm in la la land with that stuff :( I do know a 2400 will be funner than a 2000, 2000 seems like it would be close to stock. Be sure and get a good tranny cooler tho, bigger is always bigger in that category.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
