2005 Trailblazer Air Filter Cover
capesk8p
I have a 2005 Trailblazer with a 4.2L engine. Why does the air intake assembly have two inlets going in to the top of the air filter cover? Prior to the air filter there are two inlets with one going to the air filter chamber and one going to the air filter cover. The other inlet going into the air filter cover is located between the air filter and the engine. Isn't there a chance dirt will enter the engine since there is no filter on the inlet going into the air filter cover between the air filter and the engine?
yea,you got it,the engineers did that on purpose ,come on,think.not a good question ,you wasted my time cause im mad.
Ernie,
I see this is your first post. Welcome to the forum.
Not exactly sure what GM Tech4 is telling you here. Maybe he is joking with you and will come back with an explanation. I am not a Tech but I wish I could take a look at a Trailblazer to see exactly what you are talking about.
Ernie,
my explanation is that it is a question that should not be here for a tech to answer,the air filter design has to be ok or engines would be piling up,he does not understand is all,the engine is filtered period,end this nonsence.
Robert, I just saw this was his first post to the forum and possibly he is not what is called a "car guy". He was curious as to how the air intake worked and simply asked a question. I would not classify this as "nonsense".
I like having new folks join in here and if we treat them decent, they will come back and be regular contributors.
As far as I know, anyone who offers advce or comments here is not being paid for it. So if they choose to do so and they consider it to ba a waste of their time, they simply can stop at any time they want.
If I get close to a Traiblazer or an Envoy in the coming days, I will take a look at it and see what he is talking about.
no your right and I appologize ,carefull,trailblazer air filter housings are a pain to take apart,take care.
No he didnt waste your time you did by posting something worthless. He ask a question because he wasnt sure what was going on now with that being said is the hole your talking about plugged on the inside? it may be. My wife had a 2003 Trailblazer and I know what your talking about but the hole was plugged down inside.
if you look at my 6:16PM post ,I did apologize,i think I hit the quote button,so it is the same print colour as the quote .
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
