Starter Solenoid Female Torx Driver
I have a set of female torx sockets but the socket is too big to fit in the channel. I need a female torx with a screwdriver handle but I can't find it anywhere. This is to remove the solenoid from the starter.
Have a trusty Sears nearby? I have a set of their Craftsman brand and they seem pretty well made. For a single, I'd think any major auto parts chain should be able to fill the bill.
Napa didn't have one and said they'd never seen one. That was the first place I tried.
Hmm... Weird I used to work there and I could have sworn we had them... Although it's hit and miss with the sales guys there, some of them really know there cars, and others only know how to type your info into the computer...
In a pinch, I have used a 1/4 inch drive 12 point socket that fit snug on these fasteners. If you are careful and go easy getting it broken loose, it eill get them out. I know it isn't the proper tool ,but it has worked.
Just a thought.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
