Fs...nbs Bolt Ons
Erik F
I have for sale used for 07 NBS:
1- Borla single side outlet exhaust- Will fit regular cab long box, or Ext Cab 69.3" box trucks with either the 4.8 or 5.3 (not sure about 6.0) $425
1- AEM Brute Force with DryFlow Filter will fit 4.8, 5.3 and again not sure about 6.0 $175
1- 8' bed Downey Roll-up tonneau cover $175
1- 8' bed GM cargo management system rails only $175
Here is a chance for someone with a long box regular cab to outfit their truck with some great stuff. If sold to one person I will drop the total for all parts from $950 to $850. If you are interested in individual parts I will take offers...but no low ballers please. I will take offers on all 4 together also. If you would like to talk over the phone or have any questions please email me at efrancey(at)yahoo.com
Erik
Nobody interested in these parts for 07 and newer GMC or Chevy? Guess I will have to lower the prices.
Borla exhaust now $300
AEM Brute Force $125
Downey 8' Tonneau Top Spin $125
OEM Cargo System $100
OR...For one buyer to take all $500 plus shipping
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 986 Guests (See full list)
