a good friend of mine recently bought some 8500K HIDs for his 05 Ram..they are super bright but too blue for me...6500k is even brighter with less blue and more crystal white..im debating whether its worth it or not..i have halogen bulbs in right now and i see fine..does anyone have 6500K HIDs..is it a Huge Difference? worth $300.00?
8500K on 05 Ram
...too blue?
I have 6000K HIDs in my YukonXL.
I've tried most of the regular 'better than factory' lights....blue xenon, Silverstars, etc.
Nothing comes close to the results of the HIDs.
Would I do it again in my next truck....oh yes!
I've got 6000K and once you have HIDS you will never want to drive another vehicle with halogens. and I got mine off ebay for $88.00 shipped!
I think mine are 6500k and i love them, I've had everything from 6500k-10000k and these have put out the best light without much blue or purple tint to them, I bought mine on abay for $95 and have had no problems with them whatsoever.
Paul
I'm thinking about adding the HID's to my truck as well, what is all involved in the install? Do thay just install in the orignal headlamps? Is there addtional wiring required?
i have 6000s as well. they have just the right amount of blue to them. from now on, any car that i ever own will have HIDs. they are awsome.
stay away from ebay all those hids come from china bad quality stick with mculloch, helios, prolumen, jdm, mtec, xtreme hid those are the good ones they all reatils from 250-300 dollars but i guarantee you it will be worth it just try this simple method if you get to buy hids from ebay get those 90 dollars install them you will see that in the daytime they will flicker cuz you know about the drl those new chevys nah uh messed up my fuses blew them out why because there no good all those brands are mentioned work with your headlight system there digital they wont mess up your headlight system and are brighter too than those china made kits there are several let me rephrase that almost all hids that they sell are from china just check the price and you will see and compare oh and read their feedback you will be susprised i have mcullock 6k myself on both low beam and fog light and man you will see the difference i guarantee to you!!!!!!!
I agree 100%. It's McCulloch or Philips or its nothing. The HID's are supposed to use less current (35w as opposed to 55w) but many of the $99 imports use MORE current because of very inefficient ballasts, poor grounds, etc and many will cause a lot of interference with some electronic equipment like your radio. The excess current draw will also blow fuses, very aggravating. I just put the Philips kits from XenonPros in my highs and lows and they work great, installed very easily, and do not blow fuses. They came with all the proper cables and adapters, nothing to cut or splice, and genuine Philips ballasts and bulbs.
As for color, 4000k to 5000k will give you the most useable light and will be very white. As you go from 5000k to 6500k you will start to get a little blue and on to 1000k which will be very blue, and in some cases purple depending on the manufacturer. On to 12000k and you are in the purple range. Color will vary from manufacturer, but the better manufacturers (Philips & McCulloch) will at least be consistent at the same color temp. The cheap ones have very poor quality control and it is not uncommon to have a pair of lights of the same advertised color temp be slightly different colors.
In any case, HID is the way to go. Once you go HID you will never go back to halogen.
FTR 4300k is factory color and is the brightest for optimum output
I have 6000Ks and they look fine. . .actually a little too blue for me as I like a pure white look. Sadly my supplier didnt have 5000k
Here is a link to mine. . . about half way down the page
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,164 Guests (See full list)
