1993 Jimmy Starting Troubles
jken0904
My 1993 GMC Jimmy 4 Dr SLT 4X4 is having trouble starting, it acts like the battery is dead but if I turn the wheel really hard after the third key turn or so it wil start, I really would like to know what it could be someone please help me I am a single mom and cannot afford the $60 for the GMC shop just to "look" at it
Welcome to the site.
I'm not understanding what you mean by "turning the wheel" but from what you are saying, your problem might well be aging battery cables or even a starter that is going away. Perhaps with a little more elaborate description one of us can help. Give us some more details and we will try.
When you try to start it does it make any noise. Like one single click or click,click,click,.....
Do you notice anything not coming on when you turn the key to the on position?
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
