Replacing Front Tow Hooks
I had given the idea to a friend before i bought my truck and am now looking into doing it myself. Is anyone aware of a place i can purchase a conversion for my front tow hooks to chrome D Rings? Just thought it would look kick ass. Thx in advance
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 986 Guests (See full list)
