Push Button Auto 4x4
I need a part number for the 4x4 switch for a 99 old body style with auto 4wd. This is the one that is on the right side of the steering wheel. All I can find are ones without the auto or the newer ones on the left side of the steering wheel.
Thanks
I'm trying to find one too...NEW ...not used...probably would have the same problem mine has...every place I have looked on line says they don't have the part for our OBS...('97-'00 4 button switch)...someone mentioned in another thread they were $50 then disappeared and hasn't responded to where can you get one let alone for $50...
Bill
  • 1 year later...
Part arrived from UPS minutes ago...disconnected old switch...plugged in new switch...check for function: 2 Hi, Auto, 4 Hi, 4 Low...turn on headlights, switch backlights perfectly...and it is just that easy.
I had no idea GM still made this switch (19168765) and looked on ebay...for not much more than an unwarranted old part (probably has the same problem as mine as I read this is a common ill) off of ebay I have a new Genuine GM part installed and my 2000 Cadillac Escalade (Tahoe putting on airs ;) is back running like it should.
Thanks again,
Bill
