Exhaust Question Again
So I was just lookin around on borlas website and I notice they offer a single in dual out muffler. Has anybody every heard a set up like this? I was listening to sound clips and man that borla sounds the best by far and I was wonderin how they sound in person. I was going to run a flowmaster set up but now think I am going to have to change my mind to the borla. Do you think it will sound any thing like the F Bodies with borla? I wouldnt think it would sound as awsome. But i can hope right!
I personally hate most Flowmasters, but really like my Magnaflow. Sounds real good, and it is single in dual out stainless steel warrantied for life.
I have a single in to dual outs flowmaster 50, and it has a quiet rumble at idle, and its loud when you really step on it, but its noticible but not annoying below 2000 rpms (normal driving)
I had a borla on my 01 and I really liked it. Reasonably quiet when idling around but when you romped on it, it was pretty loud. I had a little resonance at highway speeds but it was a Tahoe and I don't think you get that in a pickup. A little soundproofing eliminated the drone. Overall I liked it a lot and it held up very well in 6 Chicago winters. I am strongly considering a Corsa on my new ride. Heard nothing but good about them as well.
Guest chevydeerhunter
The clips sounds great. But he has a 438 twin turbo motor installed so I don't think your exhaust will some like his.
You're right, but that's one bad ass Sierra!
I'm running the GMPP system on my truck which is the same as Y-pipe Borla duals that you speak of (Borla makes the GMPP exhaust). I would compare it to an F-body or a 350 vette. I love the sound of it. When I surprised my buddy with my new truck, I had it hidden in the garage with him standing outside off to the side so he couldn't see it. With the garage door open, I started it up. He thought it was a truck at first. Then I told him to hold on a second while I revved it up. Then he thought it was a Camaro SS or a Firebird. So sight unseen, it really does sound like a 350 out of an F-body or a vette. I'm really happy with its sound and I get a lot of compliments from gear heads all the time. Some kid attacked me at the gas station the other day. "Dude, your truhk sounds effin sweet man! ...I love Chevys!" Then I looked over to see him filing up his Kia. ...kids these days.
they dont make the GM in a single side out though if i am corrent
GM Performance Parts
Cat-Back Exhaust System
17802232
Performance, Dual Exhaust, Bowtie Logo on Tip, Crew Cab, 5'8" Short Box and Extended Cab, 6'6" Standard
17802231
Performance, Dual Exhaust, Bowtie Logo on Tip, Extended Cab, 5'8" Short Box, LMG, LH6, LY2, LY5
17802230
Performance, Dual Exhaust, Bowtie Logo on Tip, Regular Cab, 6'6" Standard Box, LMG,LH6,LY2,LY5
17801989
Performance, Single Exhaust, Bowtie Logo on Tip, Crew Cab, 5'8" Short Box and Extended Cab, 6'6" Standard
88968553
Performance, Single Exhaust, Bowtie Logo on Tip, Extended Cab, 5'8" Short Box, LMG, LH6, LY2, LY5
17801987
Performance, Single Exhaust, Bowtie Logo on Tip, Regular Cab, 6'6" Standard Box, LMG, LH6, LY2, LY5
17801988
Touring, Single Exhaust, Bowtie Logo on Tip, Crew Cab, 5'8" Short Box and Extended Cab, 6'6" Standard
17801986
Touring, Single Exhaust, Bowtie Logo on Tip, Regular Cab, 6'6" Standard Box, LMG, LH6, LY2, LY5
17801984
Touring, Single Exhaust. Bowtie Logo on Tip, Extended Cab, 5'8" Short Box, LMG, LH6, LY2, LY5
19159431
For use ONLY WITH GROUND EFFECTS - Performance, Single Exhaust, No Logo on Tip, Extended Cab, 5'8"
19159433
For use ONLY WITH GROUND EFFECTS - Performance, Single Exhaust, No Logo on Tip, Crew Cab, 5'8" Shor
Exhaust Tip
17801928
OE - Bowtie Logo, Single Exhaust, Dual Wall, Angle Cut, Highly Polished
Exhaust Tip
17801926
OE - Bowtie Logo, Single Exhaust, Dual Wall, Straight Cut, Highly Polished
Exhaust Tip
17801924
OE - Bowtie Logo, Single Exhaust, Single Wall, Angle Cut, Chrome
Exhaust Tip
19159428
OE - For use ONLY WITH GROUND EFFECTS - No Logo, Single Exhaust, Dual Wall, Rectangular, Highly Polished
Performance Air Intake
17800809
Not for Engiens LFA, LMM, LU3
Tire Inflator Kit
19159309
w/ Compressor & Sealant
Thats what I wanted to hear! Thanks dude Borla it is! :banghead:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
