Rotora
Im looking at upgrading to slotted/ drilled/slotted rotors soon and didnt know if there were any good brands that I should be aware of. Performance is improtant to me but price is as well . . .
I was looking at these or these
>> Also can I get 4WD rotors on a 2WD truck?
and yes I know I misspelled the title. . . I just dont know how to edit it :rolleyes:
