Torque Rating
I am going to be installing the Rough Country Leveling Kit on my o7. I was wondering if some one can tell me the torque rating that I will need to torque the bolts to after I install the blocks. Also I have the rough country that has 3 blocks. do i need to install of the block to make it level with the back. My truck is a 2 wheel drive.
Dano, best to call Rough Country with those questions. They have instructions on their website also, but they shoulda come with the kit. They will tell you what you need to know (I have bought kits in the past from them and they are really helpful).
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
