Stiff Steering?
Hi All,
New 2007 Silverado 4WD Ext Cab 1500 owner here. On left turns I find the steering wheel fights me a little...jerking sort of. Fluid is fine and it usually only happens when turning left while in turn. Can turn the wheel no problem at a stand still....but when moving in a turn the wheel fights me sometimes....any suggestions?
Hi All,
19 views and no responses?
FWIW, when my truck was newer (13k now), the steering was noticeably stiffer when turning the wheel quickly to the left (to avoid an unseen shopping cart in a tight parking place, for example). However, this issue has not appeared for the last few months.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
