Off To The Dealer Tomorrow
The other day my right front turn signal did not work so I found a blown fuse, fixed it. Today I go to pick up my girlfriend and my passanger side door does not open from either inside or out. It locks and unlocks with the keyfob and all the other things on the door work. WTF!!!!!!!!. Anyways had to vent. :sick:
Im happy now, so I go to my dealer this morning and tell the service guy what the problem is and they pretty much take my truck right back. An hour later the service guy tells me they do not have the part and they will have it overnighted. So befire I can even ask he tells me that the dealer is renting me a car till my truck is done. Even though the problem sucks im very happy with my dealer in the fact they actually care about there customers. Hard to find these days!
It's great to find a dealer that actually has a rockin service department isn't it? A good service experience will make us forgive minor problems that are bound to crop up on most any vehicle. Good luck getting it resolved. :)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
