01 S10 Blazer, Computer Relearn Needed For Engine Replacement?
ok i had my engine replaced and since then ive had alot of problems. this is the 4th time it has been in the shop but this issue has been since day one of the replacement but they wanted to get all the other issues fixed before looking at this. on the highway it does not go higher then 2000-2500rpms so it is slow as a dog and passing ppl is impossiable. the shop has their hands up saying they dont know what the issue is, all the tests they ran say everything is working as it should. they posted it on some service they belong too to see if anyone else had this issue because they simply dont know they said. they are pointing my tranny but im telling them it was never like this before the new engine.
my friend suggested i tell them about a computer relearn thingy. does this have to be done? and if it wasnt done would it show any codes? no codes are coming up.
If the new engine was from the same year as the original and everything got hooked up correctly, I don't believe you should still be having a relearn issue. If the engine dogs out at ~2500 rpms, it sounds like a plugged catalytic converter. Get underneath and rap on the cat with a rubber mallet or your hand (with the exhaust cold) and if you hear a rattle sound from inside the cat, it's plugged and needs replacement.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
