I sold the truck but still have the wheels and can't decide if I want to put the on the new truck.07 Black cc chev nbs
Pic is now on post 12,scroll down.
I thought about possibly purchasing those rims, but i'm still indifferent. They doo look good but I for myself, would want some black color with my chrome rims...I just think it's too much chrome for a black truck...but like i said, that's just me...
I attached two pics..one of the spank...and the other of the ones i'm considering...
I think they look nice!! What makes you think they wouldn't look nice on the new truck?
Which rims are on the new one now?
They just seem kind of dated.I've had them for about 4 years now but they're still in perfect condition.
I have the stock Chevy 20's on now.
Go with the spank's! They look super sweet, my buddy has them in 22's for his 07
Any pics of your bud's truck?
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
