:thumbs: Third sh!tstorm of the year? Gotta love it
What do you expect from shit faces?
Speaking of, where's Rob?
How long will it take for him to be banished this time? :lol:
  • Replies 391
Top Posters In This Topic
Hell, I'm a redkneck cracker. Well thats not all bad. :lol:
What exactly is that?
If you were from the south you would know.
LOL us folk up north are so sheltered...all we know is cold and snow
I just want to see a pic of palerider in his Tundra flipping me off...
Edited by alaskaLTZ
Cracker [krak-er]
Originally used as a term by British generals in letters home to make fun of Southern American wheat farmers who turned there wheat into crackers to survive the winter.
Redneck [red-nek]
Term derived from someone who spends a lot of time laboring outdoors and receives a "red neck" from the sun.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
