I have to remember to stay up later each night in order to get in on the fun. I hate not being present when another roast is on. :lol:
  • Replies 391
Top Posters In This Topic
Hey trailrider! Oh never mind I'll jackoff :lol::thumbs:
:thumbs::lol::lol::lol::D:lol:
LMAO on this one! :lol::lol:
Damn, I'm gone for one night and get owned. :lol: Where's the love? :thumbs::thumbs:
FU2
Here's the love.
I feel honored Daddy. I will vow not to make fun of your 20s for at least 3 hours.
You can make fun of them all you'd like. I am secure in my Wheeluality. :lol:
Dang Daddy, I didn't know your women were talented.
Did you run Jeff off Daddy? Have you no conscience? :lol:
He's down at his local spot, bankrupting them.
I may be fat but you're ugly...and I can diet. :lol::thumbs::thumbs:
(I'm not really fat, but I had to use this one)
leave pun alone :thumbs:
Chris Crocker owns a Tundra. Thanks for letting us know Chris, uh Trailrumprider, uh DAVE.
:lol:
Did you run Jeff off Daddy? Have you no conscience? :D
I may be fat but you're ugly...and I can diet. :crackup::crackup::crackup:
    • They’re not the same wiz as 10-15 years ago.  QC has fallen pretty hard.  The XP line was never good though in the first place.    https://bobistheoilguy.com/forums/threads/wix-filter-rusted-through.386492/post-6991372   https://bobistheoilguy.com/forums/threads/i-ve-used-my-last-wix-filter.27299/   https://bobistheoilguy.com/forums/threads/looking-for-a-better-replacement-for-wix-51258.403977/   https://bobistheoilguy.com/forums/threads/convince-me-in-using-the-purolator-boss.401537/post-7420147   the forums are littered with posts and examples of not great wix filters the last couple years
