37" Tires On A 6" Lift
Hi, does anyone know if i can run Toyo Open Country 37x13.50R17 on
my 06 Silverado Z71 Crew Cab with CST 6-8" Lift Kit. Right now im running
Toyo Open Country 295/70/R17 (33.5x11.9R17) on ProComp 9001 Knight Chrome
17x9. these tires looks small with the CST kit. and if i go to 35 or 37 what gears
would you recommend me.
thanks
Not sure if you could or not but to give you an idea i have a 6in procomp and 3 in body lift and im running 37 in iroks. I have a pic in my profile. They clear ok without my torsion bars cranked up (cv's are parallel to the ground). The open countrys are a little less aggressive so I think if your lift is set at about 8in you should be ok. Gearing depends on what you plan to use the truck for. I'm going to go with 4.56s in mine, I dont offroad it much and only pull about 2-3 thousand pounds max.
Hi, thanks for your post, i use my truck as a daily driver but i work in a shrimp farm so i have to drive 65 miles of highway and 12miles of off road every day to get there. I rarely tow something and if i do is about 1 ton. but my truck see´s a lot of off road use.
you think 4.56 would also work for me?
lookin at your truck i new you would agree with my height thinkin. back in the day when i first started workin on trucks and cars 4 wheel parts told me to gear ol truck which was 2wd .... and i wanted 35"-37" tires (don't hate) to gear it 4.56. so that sounds good. if i had 33"s i would gear mine 4.10
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 460 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
