2000 Silverado With Rear Sliding Window
I am new to the forum, so first off, I have a 2000 Chevy Silverado 1500. It is the ext. cab, step side 4x4. It came with the sliding rear window. Ever since I bought it, it has leaked. It looks as if the casing around the window is cracked. I was wondering if anyone else has had this problem too. Thanks!
Yep,This was a HUGE problem,GM realized this and discontinued the rear-slider option in mid-2000 until a new redesigned one came out in mid-'03.
I went through this with my '99 until the new one came out and they changed it for me.
You said they replaced it, was that like a recall or did that cost you something to get that done?
No,No recall.
It didn't cost me anything though because my first one cracked around 8,000 miles so they replaced it,that one cracked not long after that so they changed it again,By that time they realized the problem of the frames cracking and pulled all remaining stock,I just used some clear silicone in the two cracks I had until they came out with the new design window.
Then when the new one came out they replaced it under a "special warranty policy" for me even though my truck was out of warranty and because of the past history of the issue they covered it for me.
No,No recall.
O allright thanks
Did you buy the truck new or used?
If you post your VIN I can run a warranty service history on your truck and see if it has been replaced before.
I can also run a build sheet to make sure it is a factory sliding window,although it sounds like it is.
The VIN # is 2GCEK19V4Y1156594, Thanks!
Nope,Its never been changed before,Heres the service history and build sheet....
GM Vehicle Inquiry System
Claim History
VIN : 2GCEK19V4Y1156594
CLAIM HISTORY
Repair Order Date : 05/21/2007 Repair Order Number : 134575 Odometer Reading : 92451 miles
Serviced By : STAFFORD CHEVROLET INC.
PO BOX 68
DRYDEN, NY 13053-0068
(607) 844-8113 Selling Source : 13 - CHEVROLET
Site Code : 15058
Business Associate Code : 166292
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
08/10/2007 820 01 # V1462 - 06019 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 88980509 - CBL-E/GAT N
06/01/2007 800 01 # V1410 - 05068 - INSPECT WHEEL SENSOR (INC. CLEANING) N/A N
Repair Order Date : 09/13/2002 Repair Order Number : 032679 Odometer Reading : 53275 miles
Serviced By : GILLESPIE CHEVROLET
PO BOX 526
UNION SPRINGS, NY 13160-0526
(315) 889-7332 Selling Source : 13 - CHEVROLET
Site Code : 15071
Business Associate Code : 115303
09/17/2002 309 01 # V0881 - 02029 REPROGRAM SDM N/A N
Repair Order Date : 05/18/2001 Repair Order Number : 151080 Odometer Reading : 30930 miles
Serviced By : BILL COOKE CHEVROLET-OLDSMOBILE-CADILLAC, INC.
35 CINEMA DR
ITHACA, NY 14850-1631
(607) 272-9292 Selling Source : 13 - CHEVROLET
Site Code : 15111
Business Associate Code : 117013
06/08/2001 176 01 # J5490 - THROTTLE BODY ASSEMBLY REPLACEMENT 17113665 N
Repair Order Date : 03/27/2001 Repair Order Number : 147204 Odometer Reading : 28487 miles
35 CINEMA DR
Site Code : 15111
04/06/2001 158 01 # V0609 - INSPECT BRAKE PIPE & INSTALL SPACER CLIP 15054936 - CLIP N
Repair Order Date : 06/07/2000 Repair Order Number : 155472 Odometer Reading : 13727 miles
Serviced By : FOX CHEVROLET, OLDSMOBILE, CADILLAC, INC.
318 GRANT AVE RD
AUBURN, NY 13021-8690
(315) 258-2000 Selling Source : 13 - CHEVROLET
Site Code : 15159
Business Associate Code : 115277
06/16/2000 74 01 # J5485 - BODY, THROTTLE - R&R N/A N
06/16/2000 74 02 # V0486 - 1999-00 CV & GMC C/K 1/2T P/U - INSTALL NOTICE LABEL N/A N
Repair Order Date : 05/16/2000 Repair Order Number : 154428 Odometer Reading : 12574 miles
318 GRANT AVE RD
Site Code : 15159
05/19/2000 66 01 # N9995 - CUSTOMER CONCERN NOT DUPLICATED N/A N
Repair Order Date : 09/22/1999 Repair Order Number : 156594 Odometer Reading : 0 miles
Serviced By : ROYAL CHEVROLET-OLDSMOBILE-PONTIAC-BUICK, INC.
PO BOX 278
SAYRE, PA 18840-0278
(570) 888-9691 Selling Source : 13 - CHEVROLET
Site Code : 15236
Business Associate Code : 115406
09/24/1999 997 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
© 1998-2005 General Motors Corporation. All Rights Reserved.
Vehicle Build
VIN 2GCEK19V4Y1156594
VEHICLE BUILD
Merchandising Model : CK15753 -2000 SILVERADO LS 1500 PICKUP
Gross Vehicle Weight Rating : 2906 kg (6408 lb)
Order Number : BVRVSB
Build Date : 09/22/1999
Build Plant : 2Y153
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AE7 - SPLIT BENCH RECLINING FRT SEAT
AG1 - SIX-WAY POWER DRIVER SEAT
AG2 - SIX-WAY POWER PASSENGER SEAT
AM7 - FOLDING REAR SEAT
AU0 - KEYLESS REMOTE DOOR LOCK AND TRUNK OPENER
AU3 - POWER DOOR LOCK SYSTEM
A28 - SLIDING REAR WINDOW
A31 - POWER WINDOWS
B30 - WHEELHOUSING & FLOOR CARPETING
B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR KEYED FLOOR MATS
B85 - BRIGHT BODY SIDE MOLDINGS
C60 - AIR CONDITIONING
C7H - 6,400 LB GVW RATING
DK7 - INTERIOR CUSTOM ROOF CONSOLE
D48 - ELECTRIC EXTERIOR MIRRORS
EVA - EVAP EMISSION REQUIREMENT
E62 - SPORTSIDE BODY
FK2 - TORSION BAR SPRING ADJUSTMENT
FK3 - TORSION BAR SPRING ADJUSTMENT
GT4 - REAR AXLE - 3.73 RATIO
JC5 - 4 WHEEL POWER DISC BRAKES
KNP - HD AUX TRANSMISSION COOLING SYS
K34 - ELECTRONIC SPEED CONTROL WITH RESUME SPEED
K68 - 105 AMP DELCOTRON GENERATOR
LR4 - VORTEC 4800 V8 SFI GAS ENGINE
M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
NC7 - FEDERAL EMISSIONS OVERRIDE
NF2 - FEDERAL EMISSION SYSTEM
NG1 - EMISSION CERTIFICATION
NP5 - LEATHER WRAPPED STEERING WHEEL
NP8 - 2-SPEED ACTIVE TRANSFER CASE
OSG - PLANT CODE,OSHAWA
PF9 - WHEEL 16 X 7,ALUMINUM CAST
QNK - P245/75R16 ALS BW TIRES
SLL - SOLD ORDERS
UN0 - AM/FM STEREO W/CD PLAYER
UQ3 - ENHANCED AUDIO SPEAKERS
UY7 - HD 7-LEAD TRAIL. WIRING HARNESS
VB3 - CHROMED REAR STEP BUMPER
VG3 - FRONT DELUXE CHROMED BUMPER
VR4 - WEIGHT DISTRIB. PLATFORM HITCH
VXS - COMPLETE VEHICLE LABEL
V22 - DELUXE FRONT APPEARANCE
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XNK - P245/75R16-109S ALS BW TIRES
X88 - CHEVROLET CONVERSION
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
YD6 - BASE REAR SPRING
YE9 - SILVERADO
YNK - P245/75R16-109S ALS BW TIRES
ZNK - P245/75R16-109S ALS BW TIRES
ZY1 - SOLID PAINT
Z82 - HEAVY DUTY TRAILERING EQUIPMENT
Z85 - INCREASED CAPACITY CHASSIS PACK
1SB - OPTION PACKAGE 02
1SZ - PREFERRED EQUIPMENT SAVINGS
51U - DARK CARMINE RED METALLIC
6WY - FRONT SPRING
67I - INTERIOR TRIM - LT OAK
672 - TRIM COMBINATION - LEATHER OAK
7WY - FRONT SPRING
Delivery Information
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 10/12/1999
Delivery Type : 010 - RETAIL/INDIVIDUAL
Delivered Odometer : 30 miles
Delivering Dealer :
PO BOX 278
SAYRE , PA 18840-0278
(570) 888-9691
Delivery Selling Source : 13 - CHEVROLET
Delivery Site Code : 15236
Thanks for getting that paper. It's interesting to go through this sheet, like it had a CD radio installed and now it doesn't. :D
