Tapping Noise
I have a 05 chevy silverado 1/2 ton. I have a tapping noise coming from the dash or firewall area on the passenger side. It does it with the key on even if the engine isn't running. I turn the fan all the way off and it still does it. Does it with the radio turned all the way down too. Any ideas? Its like a tapping noise. Like tapping on something. Any help would be great. It annoying the hell out of me! Thanks
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
