Wheel Bearings
Hey guys just looking for some help here.. i need at least a new drivers side wheel bearing hub.. my mechanic says i only need to do the one.. but i kinda don't like the idea of doing just one. my 03 Tahoe only has about 60k on it and i recently added some 22's and now i will be adding a wheel bearing or two..
First.. what is the best route i have found lots on ebay for around 100 bucks with lifetime warranty.. but i am looking for the best option and the least expense
Second is there an improvement.. maybe 2500 series or such.. thanks Pete
$100 sounds very cheap. I would check some reputable online sources and some local parts shops. I changed my driver's side wheel hub assembly at around 65k miles and installed a Timken hub which ran about $140. There is no reason to change out the other hub if it's not bad. Save your money. For the part on Ebay, bare in mind that a lifetime warranty doesn't help if you have to do the work again in the near future and if getting the part replaced involves a big hassle. Saving a few bucks in the short-term may not always pay off so research the part brand before buying.
Yeah, I'd go with a good local auto parts store for the bearings. Also still avoid the cheap stuff. As for the other bearing, did he actually really check it out, or just check for play in the wheel? Personally, I would also probably change both if were going to put some heavy 22's on there. Your call of course.
I would have to agree. I would change both although the other side may last another 60K, it may also go next week and unless your budget will not allow, I would do both. Federal Mogul (BCA) is our (CARQUEST)premium line supplier and think NAPA has Timken. I would not be afraid of either. We do carry an economy line and have had really good luck with them.
I would suggest you avoid any no name brand for this application. Afterall, these can be a safety issue and/or put you down on the road. Not a risk I am willing to take to save a few $s.
Ditto on the Timken recommendation.
I'm not sure who supplies OEM GM bearings, but they were toast by 50k miles on my Burb. Meanwhile the factory Timken bearings on my 4wd Cherokee are going strong with 160k miles and 35" MTR's.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,098 Guests (See full list)
