Reading Obdi Abs Codes
Is there a way to read ABS codes on a 95 Sierra?
I know how to pull the DTCs.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
