Heated Washer Fluid
Just checking on others experience good or bad.
My truck came with the heater window washer fluid option.
I thought it was poorly designed. You hit the button to turn it on. It heats in about 30 seconds and then sprays the washer fluid basically below the window. Once it is done the blades start moving with no fluid on the window.
I guess the same can be said under normal conditions. Why did GM design the fluid to come out from the bottom of the blades.
Does anyone else have this problem or am I just nit picking? :thumbs:
Fluid should come out of the nozzles (once its heated) as the blades are wiping,at least thats what mine does.
well both of our trucks when it first starts ya see steam and fluid come out. once it is heated then it sprays while it wipes, it does this 4 times which makes a cycle
Thats how I shoulda' said it...Mine sprays while it wipes! :thumbs:
On my YD it does both.
It sprays, after heating up, just prior to wiping (I would think this was designed to unstick the blades if frozen on) and then also while the wipers are working.
Yep,Mine does that too (Sprays,after heating up,just prior to wiping)
I need to have another cup of coffee this morning before I reply,since I can't type what I'm thinking :thumbs:
I thought that Heated Washer Fluid to help remove bugs in the summer also...the only thing I ever have found the heat to be nice for is when the windshield is frosted....I don't have any luck gettting the bugs off in the summer with it. Maybe I'm not using the right kind of windshield solvent?
Na...Mines the same way,doesn't do much to get the bugs off.
It sounds like its the same nozzle system theyve been using for a while, just heated correct? The nozzles are on the blade not the hood, something I personally find to be way better.
Yep. It's a pretty cool setup and I've found it very handy :lol:
It is very handy when the temp drops and it start to snow that heavy wet stuff. Got into some of that the other day. Temp dropped 10 degrees in about 10 miles and snowed VERY hard. The windshield iced up fast. So until the defroster caught up, the heated washer kept things clear.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,208 Guests (See full list)
