No G80 Differential! :(
Well, I just realized my K1500 doesn't even have the G80 differential. :D I plan to do some mild off-roading eventually, will this greatly impair my truck's capabilities? That's the whole reason I got a 4WD truck in the first place. :thumbs: Anyway, would it be worth it to buy a G80 rear end for my truck, or maybe the Detriot Truetrac or Auburn Pro that I've been reading about? My truck is primarily for on-road use, but I like to have real 4WD when I need it.
Also, would getting a good locking differential such as those mentioned above outweight just getting a set of off-road tires such as BFGoodrich Mud-Terrains? Actually, a set of tires would probably be more expensive than a differential, wouldn't they? I'd still like to know the answer to that, though. :lol:
Thanks! :D
peterson 4wheel magazine just did a article on traction vs travel, they made a good point about the locker. It can put you into alot of off-road situations you rig is not ready for. In my personal opinon a locker isn't worth a @#$% if you have crappy street tires. If you don't have good tires what is the difference between spinning one wheel or two. I would go with the good tires first, but a locker would be a future mod for sure. I recently upgraded to a g80 and I have noticed a world of difference. I no longer need 4 wheel drive in areas I did before. I also have decent tires too. An ARB airlocker may be a route to take also, I have heard alot of good things about them. You may even be able to pick up a whole used differential with the proper gears and everything for a few hundred bucks. I would go with the tires first though.
Right now I have 265/75-16 Michelin LTX M/S tires, which seems to be a popular choice for general use, and they seem to have done pretty well with everything I've done considering they're meant for road use. I'm sure some nice M/Ts would be quite a bit better, but I haven't run into any situation where the tires were an issue.
I went off-roading today for the first time at a popular local spot and it did fine, but I did run into one situation where a locker would have been nice. It was an up-hill diagonal bump and I didn't have good traction on the front left and right rear tires, which of course received all of the power. I managed to manuever out of it, though.
I just took the Mud Terrain (not BFG brand) tires off my Suburban (4X4) and put on BFG ATs. The difference in the noise and ride is HUGE! I just put 260 miles on the truck today going to Cincinatti; it was a pleasant trip. My point is that if you do the majority of your driving on the road, you may regret the MTs. You may want to consider either "settling" for aggressive ATs or get another set of rims with MTs for the days you want to do some serious off roading. If your current tires have a reasonable amount of tread, getting some black steel rims and MTs may be rather attractive.
Actually, now that I've "found" this off-roading spot I think I'll be going more often. I don't care much about the noise, but more about the ride quality, I suppose. I do have the plain 4x4 model and not the Z71 model, so I do have a softer ride already with the smaller shocks. Most all of my driving is around town (very rarely do I do any freeway travel in my truck), if that makes a difference. I don't plan on getting new tires too soon, as the current Michelin LTX M/S tires have a lot of life left and it'd be a waste to get rid of them. I guess I could just keep them after having them removed, though, couldn't I?
So you guys think I should get tires first? I didn't seem to have any traction issues with the current tires despite the fact they're meant for on-road use. I think in the situation I was in (see my previous post) was because of not having a locker rather than tires, as the two tires with traction weren't moving, just the two without. Even with my tires I think the locker would have kept that situation from happening. What is you all's take on that?
Thanks for all of the help so far! It will be a while before I get this stuff done, I just wanted to know for future reference.
I would agree that tires wouldn't have made much difference; a locker would have made a great deal of difference. Save up your money for the locker! :lol:
Yeah, if I were doing more mudding, I'd definitely get the tires first, but I think in my situation where I'm going over obstacles and such a differential might be better. Plus I can wear out the tires more evenly. :D
