Turn Signals Waaay To Loud!
I added an amp and speakers to my nbs sierra and now the turn signals and chimes are really loud. I set the volume through dic to the lowest setting of normal. Is there any thing else I can do?
Based on the title of your posting, I thought that maybe you got the RPO code SFTS (South Florida Turn Signal) option by mistake.
My bad :thumbs:
My bad :lol:
:thumbs:
My bad :lol:
:lol:
Thanks, that was it. I bought one of pac's adapters and it had level controls,quick adjustment and I don't scare the passenger when I make a turn.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 283 Guests (See full list)
