Check Out My Hids On 08 Denali
Here is a picture of my new HID lights. If you want where I got them, go to Island Motorsports in Buena Park, CA and tell them Bob sent you. Ask for Regi. He will hook you up if you tell him I sent you. Awesome! It's amazing at night time, and it covers so much road. The left side is the HID and the right side is stock. Well worth the money. He can do Tahoe's, Silverado's, anything GM.
I am not far from there. I may look into that when I have the money :thumbs:
  • 1 month later...
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
