Controlled Discharge...what Is It And Is It Bad?
I have a 2002 Silverado 1500HD. The other day I was towing my boat which weighs about 4,500 pounds. I had the air conditioner going while pulling as well. After driving about 2 miles I pulled into a bait shop to get supplies and happened to hear a PFT, PFT, PFT sound coming from under the truck. I looked under and could see that the truck was discharging a fine mist of fluid in a controlled fashion. The discharge was in the middle of the truck roughly just behind the engine mount. The discharge lasted less than 10 seconds. Is this normal? What is it? Is it indicative of a problem?
I had driven the truck/boat several days before for well over 6 hours with the trans temp never topping 200 degrees. I have pulled the boat several times since with no noticeable issue.
Thanks for any info.
Dear Ware,
I can not believe this is normal.
Ken
That doesnt sound normal to me either!
If it were my truck, I would definitly visit your local mechanic/service center and get it looked at.....
Could it have possibly been water dripping off of the AC condensor onto the exhaust? I think the AC is roughly placed above the passenger side exhaust manifold and CAT.
Just reading the topic to this thread, I thought it was some personal medical problem. :lol:
Yea, I thought that too. I initially expected to see something like "Ok, I stuck it somewhere that I should not have and now it hurts when I pee..."
If it is the A/C I think you should see the water on the pasanger side of the truck, I have noticed this before with my truck.
My '03 did this and my '07 classic does it also. Ticks me off that in those 4 years they didn't figure out to put a little drain tray there to direct the condensation away from the heat shield. Very annoying, and seems like it would accelerate rusting of the heat shield.
If you have stock exhaust, you should be able to hear it at idle, from the driver's seat with the windows down. Roll your window down at a stop light sometime when you are running the A/C but not towing and see if it is still doing it.
... I pulled into a bait shop to get supplies and happened to hear a PFT, PFT, PFT sound ... The discharge lasted less than 10 seconds. Is this normal? What is it? Is it indicative of a problem?
This is normal. And I believe you've named it appropriately. As serious as it may sound, it is nothing to be scared of. In an office setting, controlled discharge is also often referred to as "crop dusting" which is a method by which one intermittently releases small amounts of gas whilst walking through a cubicle city, so as to avert responsibility for the discharge. I wouldn't worry about it in a bait shop, they're pretty stinky anyway.
Just reading the topic to this thread, I thought it was some personal medical problem. :D
first thing I thought was: they make a cream for that, don't they?
