Steering Squeek
Is there something that needs lubricated regularly? Truck has about 40k now. The dealer did replace some sort of steering shaft when it was under warranty. There was some slack in the wheel and a slight popping noise. Are there any fittings that should be greased regularly on these trucks?
There should be a rubber boot surrounding the shaft inside the cab, sometimes the grease around it dries out and you just need to spray some grease around it and it should be good to go.
