03 Silverado Abs Locking Up At Low Speeds
my 03 silverado is locking up the front drviers tire at low speeds when braking, usually when coming to a stop it happens at around 10 mph and under after the car has warmed up for about 10 min.,. its not actually locking up but the abs is kicking on and pulling me to the left pretty good any ideas.
its ur ABS sensors. try cleanig them. if not. u will need to replace them. there might even be a recall out on it. i had 2001 and same issue. its under 20 mps and ABS malfunction. i got it replaced, then later reimbursed due to the recall.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
