Hypertech Side Effects
Nope,I've had three of them,One for my '99,my '04,and my '07.
The only issue with the one for my '07 is that it disabled the AFM,so I sent it back to them and they sent me a "Max-Energy" at no charge.
Stang233,
I have researched this far too much and found one post on another GM forum of a guy who had some pinging issues with a HT unit that he could not correct. The post was a few years old and the only one I found with an issue out of literally hundreds of posts concerning Hypertech.
From what I have found, it is the safest of any of the Hand Held units but also the most conservative. Superchip's flashpaq would be next in line as far as being safe but it will produce more power from what I have read. Diablo is next but there are a good many posts about issues with it. I think it is a great Hand Held and will produce the biggest increases but it takes a little more work to use it. There are some members here that love them.
It would also seem the Hypertech will produce larger HP and TQ #s down in the low to mid RPM range but the others catch up in the mid to upper range and then surpass it in the higher revs.
I will also add that if you contact Hypertech either by tel or via website, they will treat you like a Customer and will take the time to answer your questions. I cannot make that comment about the others and I will leave it at that.
Thank you so much for that reply. I really appreciate your input. I think i will go ahead and tune it for the 87 octane. They are saying 28hp. That is pretty good. And if you are seeing it down low that is even better. Thanks again, Richard
Hypertech programmers give you 28 hp in your mind when you program it and when you drive it and you think its faster. They actually might give you 2.8 at the most. Now if you had a diesel thats a different story
Jeff, are you saying your Max Energy is really not effective? I know they will not make a huge difference but I have read pretty good comments for the most part. Also, their dyno sheets show the numbers to be pretty good down low.
I just wondered what your experience had been and are you running the 87 or 93 tune?
I was running the 93 tune. I noticed NO difference at all from low to 3000 rpms. Ran the same. Once I matted it to the floor it felt a little better and faster.
All in all, I wouldnt waste your money. I wanted it to change shift points, rev limiter, speed limiter, and recaibrate my speedometer. I bought it for 50 from a kid at my school that hated it, and I hated it too, so I sold it for 300.03 cents on ebay lol. Also its supposed to make your MPG a little better, and it shot it into the ground. I was getting 11.6 before the Hypertech. After with 3 tanks average, I was getting 9.8-10.2. Id save your money.
Your only getting 11.6 MPG?!? :fume::thumbs: ...You got a problem somewhere,I never got less than 15 with my '99.
Also all the Hypertechs I've had (Six of them) never affected MPG,Either up or down.
Na,Don't really drive like that :thumbs:
Still though...11.6 seems kinda low even for that kind of driving.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
