Looking At A Truck
Well I have an oportunity to pick up a 2005 Regular Cab long box 4x4 6.6L Diesel 2500HD for around $24k off lease from the dealership. Any input for things to look for or be wary of? it only has 58K Km on it.
Any input would be greatly appreciated.
Oh this is obviously a Canadian truck ie the Km and it's $24k Canadian
I haven't heard of too many problems on the newer D-Max. The first edition had some injector problems. I assume it has the Allison transmision. Does the truck look like it was used for pleasure or was it worked hard? I think the warranty is pretty long on the diesel, should be transferrable to the next owner. A carfax or history of truck from dealer,if he sold it originally would help. plowking
I am not sure if it was the 2004-2005 (sometime around those years)D-max motors but they had some cooling issues also. (Had to do with the radiator and shroud being redone, and possibly the manifold, or somthing along those lines) Not real bad, but guys down south and out west towing some bigger stuff had cooling issues. Check out the Diesel place web site also, (I think that is what it is called), That being said the motors, trans, brakes are all very good, just how GM redid the cooling that kinda messed things up. I heard also that the later 2006-2007Classics were corrected and do not have any of the cooling issues.
The LLY's (04.5'-05') had cooling problems, but ours has not had a single problem. It has 50,000 miles and has been chipped for the last 10-15 thousand.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
