Raised Cardboard Thing On Floor?!
So I've had my new truck for a couple weeks now. I like it overall, but little things keep popping up: leaking oil, lopsided suspension after 2000 miles, defective GMC logo, defective stereo, and now:
I find that GM was cheap and put some sort of cardboard "raiser" on the floor directly in front of the seats - apparently to keep the floormat in place. Is my assumption correct? I put my back heal there and it crushed all the way down! What the hell? Couldn't they have molded the body metal to do the little raise?
Anyone else notice this cheapness?
It's under the carpet. While in the driver's seat, move your right foot all the way back so that your calf touches the front side of the front seat and so your knees are at a perfect 90 degree angle. Your heal will be resting on a raised piece of floor. Now rest a *slight* pressure in your heal - the carpet will collapse and it will feel like cardboard. The cardboard will pop back up - at least for now; I'm sure doing it too many times will crush it permanently.
I doubt its cardboard, plastic maybe. Here is a picture of the other side with the front seat removed. They cram a lot of electronics and wiring harnesses under the seats. I believe the airbag control module plugs in here under the front passenger seat.
Cheapness thats hidden in these trucks I am not so much upset at. Kudos to GM for keeping it out of sight. Things like lack of a rubber pad to keep your keys from banging around on the steering column or the deletion of the light under the hood annoy me more.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 901 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
