To Get Body Work Done Or No
Hello,
I have a 2000 Silverado step side. I like the size and feel like a might hold on to this truck for a few more years. However, there is rust through the rocker panels, rust on the tailgate, rust inside the door sills, and a dent in the section directly behind the door.
I went to an independent body shop and asked for a quote. he quoted me at $1000 for new rocker panels, sandblast the tailgate, fix the dent, and generally get rid of the rust and re-paint.
so my question is this. Would it be wise to do this? or is it a waste of money and i should trade up while i can? Also, through experience, will the rust just reappear in a year? or do you think it would last a while?.. I will be doing Krown oil treatment every year after this.
Hello,
1000 bucks sounds pretty cheap for all that work. Down here we don't have rust issues to deal with so I don't know how "permanent" such repairs are.
For that price, are these guy's worthy of their work? From what you're describing, it would be more like $1500+ where I'm from in Ohio. If this place has a good rating, then I say go for it. Check the BBB.
They are a relatively new place. I see a lot of BMWS, and other high end cars in there. They also did some work to a rusted ford pickup that I saw afterwards and it looked good. I don't know if it rusted a week later or not. I work right around the corner from them and they have constant business.
Ill talk to them next week and make sure we're on the same page and say go for it.
thanks for the input
As stated previously I would check them out a bit. $1000 sounds like a low price just find out what you are getting. If you wanna keep that truck for a few more years it will prolly be nicer down the road if you fix the rust rather than neglect it. Sounds like it might be worth the investment. Just my opinion. Good luck. :lol:
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 1,127 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
