05 Sierra 4x4 Low Clunk
I have purchased an 05 sierra z71 offroad crew 4x4, i am hearing a clunking sound, metal to metal from the transfer case when 4 low is activated or deactivated, it does not do it from 2 to 4 hi and vise versa, is this normal.
You will hear some noise going into low range. Do you have it in neutral? Every time I put my truck into any 4x4 i hear it switching. 4x4 low i can hear the gears go together, but they dont grind.
I have it in neutral and it is not grinding, it is more of a tinny sound, like the plunger pushing into transfer case and stopping . i think its normal but i want to be sure, truck has bumper to bumper gm warranty for 3 months
I have an 07, and it clunks pretty good when you shift into 4lo, salesman said it was normal. Also, I dont think it would shift if you didnt have it in neutral.
All my 01, 04 and 07 trucks clunked and clanked while switching
in or out of 4 wheel lo. but operated normally in lo otherwise.
Pretty normal for electric shift t-cases, it's mainly due to all the actuators forcing the gear shift. Some of the old manual shifts were a little bit loud, but mainly because of the torque shift.
My 06 2500hd and 07 1500 both can be pretty loud and I always feel it shifting in and out of 4-lo. It DOES seem to get quieter as you use it over time and the gears wear in. One thing I don't like about the electric shifts is that it takes a LONG time to get into low range.
Wouldn't worry about it. Shifting into and out of the low range gears will always make a little noise. I've never heard one that shifted to 4 low silently. As long as there aren't any funny noises after it shifts into 4 low, you should be fine. It might also help if you are rolling 1-4 mph (in neutral of course).
    CaptainDad
    CaptainDad
  • Who's Online   3 Members, 0 Anonymous, 588 Guests (See full list)
