Power Train Swap
I have a 95 gmc sierra 1500 with the 350 tbi, k&n cold air intake and msd coil/wires. I can't complain about the engine. It was taken very good care of, is full of power and reliable, but I've been considering a swap for a little more power.
My inside source contacted me the other day with a 95 LT-1, nicely built with intake, heads, cam, and headers. All it needs is a water pump and i can drop it right in. I'm looking for a swap kit with the wiring harness, preferably a "plug and play" type so there's little splicing. Can anyone help me with this?
  • 1 month later...
kuhl, to make your life a whole lot easier you would probably be better off leaving the 350 in your truck and building that to the power you want. That being said if your heart is set on the LT1 your best bet would be to contact painless performance or speartech. The have kits to make your swap pretty much a bolt in. They also build custom harnesses for individual applications. Good luck.
Pictures will be posted as soon as I can. As for introductions BJ, all you have to do is ask.
Only joking with you. And please at least put the D even if you don't put the 3. BJ just has such a negative connotation. :):sigh:
