Webphoto Account holders
Chev4Ever
I had a small question for the people who have a webphoto account.. With the recent upgrade i cant find the way to get the link for the photo...  I ve searched everything on there and i just cant find it.. It used to be really easy from there last format..
Could someone help
Steve
I couldn't figure it out either until a couple guys here helped me.  Find the picture you want to post, then right click and click on properties.  It will show the address, copy that, then use that as you did before to post, etc.  Here you can just click the image button in the post and paste the address in there and it will do it for you.
Clear as mud?
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
