Wheel Size Question
I have a 99 Z71 NBS, the wheels are 16 X 7 but if you measure the clear space from the inside of the lip to the inside of the opposite lip it is 7.5". I would like to bye some newer factory rims (07 Silverado) which are 17 X 7.5. The question is; if I measure the same dimension on these rims would it be 8". I want to put 285s on the truck and the particular tire brand I am looking at recommends a minimum of an 8" rim. I have tried to search but was unable to find the answer.
Thanks
Thanks
Well I was running 285/70/R17 on my Truck Z71 - 2006 and its was rubbing on full turn on the plastics but then leveled it by the torsion and it was ok. No more rubbing. Now I just bought the Chevy ext cab and slapped on 20's and have minor rub but just got the quick lift and hope that will take care of it :D
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
