02silveradols Posted May 17, 2008 Posted May 17, 2008 I just recently noticed that when I have my defrost on, the passenger side seems to blow less then the right side. It still works but seems a bit less. It also seems like the temp is a bit different as well but when i adjust the temp it does change like it should. I notice this a little on the other different settings such as the vents and the floor but sometimes its the opposite. Is it just the way the vents are or do i have a problem. Its the Digital Auto climate. They are both set for the same. Thanks guys
svensk Posted May 17, 2008 Posted May 17, 2008 I just recently noticed that when I have my defrost on, the passenger side seems to blow less then the right side. It still works but seems a bit less. It also seems like the temp is a bit different as well but when i adjust the temp it does change like it should. I notice this a little on the other different settings such as the vents and the floor but sometimes its the opposite. Is it just the way the vents are or do i have a problem. Its the Digital Auto climate. They are both set for the same. Thanks guys I'm just thankful mine works still.
pennzoil29 Posted May 17, 2008 Posted May 17, 2008 When I saw "normal" as the topic, I thought he was referring to us. My '99 is the same way. The passender side works fine, just not as strong as the drivers side.
K.Jump Posted May 17, 2008 Posted May 17, 2008 I just recently noticed that when I have my defrost on, the passenger side seems to blow less then the right side. It still works but seems a bit less. It also seems like the temp is a bit different as well but when i adjust the temp it does change like it should. I notice this a little on the other different settings such as the vents and the floor but sometimes its the opposite. Is it just the way the vents are or do i have a problem. Its the Digital Auto climate. They are both set for the same. Thanks guys I'm just thankful mine works still. +1
