Silverado Maintenance
I have a used 2003 Silverado and am wondering what I should do to keep it in tip-top shape. It has 85,000 miles on it. Next time I go to my mechanic I plan on getting new brake pads, an oil change, and the transmission fluid changed. Should I change the fluid in the rear axle (I have the G80 locking differential)? Is there any other fluid I should change or regular maintenance I should perform?
Yeah, I would go ahead an change the differential fluid. I have 65000 on mine and there was a lot of metal on the cover magnet. If I were you, I would also go ahead and have the plugs and wires changed.
Change transfer case, and differential fluid. Maybe the antifreeze, and blinker fluid.
I just opted for the synthetic blinker fluid; seems much smoother now.
Don't forget the "tornado" thingy and magnets to boost your MPG. :D But in all seriousness it sounds like you got it covered.
Damn dude those are some rubber band tires! :D
Just playin with p-shop!! (shaved handles and badges too!)
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
