Dam Emission
Mikeee
I read the thread in the link. I sure hope you used the seafoam BEFORE you changed the plugs. It will loosen up the carbon(which is a good thing) which wreaks havoc on the spark plugs. I put seafoam through my intake and the engine started missing right away. I drove it that way for the next few days hoping it would go away but, it didn't. The problem turned out to be the plugs. Good thing they were old anyway so I replaced them and now it runs smoother than ever. Good luck! -Lorenzo
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,401 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
