Bed Cover
I am looking for a bed cover for my truck. I am looking at the Extang Revolution Ultra Low Profile Tonneau Bed Covers. I was wondering if anybody has used them or heard anything about them.
If you do a search on "bed covers" in here, you'll find a bazillion posts and great discussions about the brands and what not. A lot of good info. I had an Access cover on mine but have now ordered a shell.
I was looking for info on the Extang Revolution last month when I was ready to buy. I could not find anyone that had one. I guess it's too new an not many people have one. I wound up buying the Truxedo Lo Pro QT and am happy with it. It's a bit more money but found a great deal on ebay for 339 which includes shipping costs.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
