Mygmlink Question
I've tried numerous times to add my VIN to my profile at MyGMLink.com, but it never does anything. It still says "Membership Status: Add VIN to upgrade for full benefits" at the home page.
Same problem here, I finally emailed them and they set it up for me.
Could someone run a VIN check for 2GCEK19T731179102. Could I have all the information availableon it including the summary and build sheet. Thanks in advance.
GM Vehicle Inquiry System
Summary
Home - Summary - Claim History - Vehicle Build - Vehicle Component - Delivery Information - Dealer Information - Service Contract - Warranty Block - Branded Title
Help
VIN : 2GCEK19T731179102
VEHICLE INFORMATION
Merchandising Model : CK15753 -2003 SILVERADO LT 1500 4WD EXT CAB Warranty Start Date : 11/20/2002
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : JOE DOWNEY CHEVROLET, INC.
PO BOX 243
CANTON , MA 02021-0243
(781) 828-3800
Selling Source : 13 - CHEVROLET
Site Code : 32439
Business Associate Code : 114951
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 04007 TAILGATE SUPPORT CABLE N/A Closed
SERVICE INFORMATIONAL ITEMS
SB 06047 ONSTAR HARDWARE CAN BE UPGRADED TO DIGITAL. SEE TSB 05-08-46-006. 02/21/2007 See Bulletin
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes OnStar Status Inactive Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped No XM Radio ID N/A XM Status N/A Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 11/20/2002 140 miles 11/20/2005 36140 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 11/20/2002 140 miles 11/20/2008 100140 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 11/20/2002 140 miles 11/20/2010 80140 miles
36/50000 CALIFORNIA EMISSIONS 11/20/2002 140 miles 11/20/2005 50140 miles
84/70000 CALIFORNIA SELECT COMPONENT 11/20/2002 140 miles 11/20/2009 70140 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
03/08/2005 028156 # E2327 - BEARING AND HUB ASSEMBLY, FRONT WHEEL - BOTH - REPLACE 39882 miles
11/18/2004 027796 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 36001 miles
08/12/2004 027362 # F1007 - UNIVERSAL JOINT, REAR PROPELLER SHAFT - BOTH - REPLACE 30031 miles
11/20/2002 024647 # A0110 - FINESSE SAND AND BUFF 11 miles
10/08/2002 A79102 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
© 1998-2005 General Motors Corporation. All Rights Reserved.
Claim History
Help
CLAIM HISTORY
Repair Order Date : 03/08/2005 Repair Order Number : 028156 Odometer Reading : 39882 miles
Serviced By : JOE DOWNEY CHEVROLET, INC.
PO BOX 243
CANTON, MA 02021-0243
(781) 828-3800 Selling Source : 13 - CHEVROLET
Site Code : 32439
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
03/15/2005 569 01 # E2327 - BEARING AND HUB ASSEMBLY, FRONT WHEEL - BOTH - REPLACE 15134584 - HUB N
Repair Order Date : 11/18/2004 Repair Order Number : 027796 Odometer Reading : 36001 miles
PO BOX 243
Site Code : 32439
11/26/2004 538 01 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 88980510 - CBL-E/GAT N
Repair Order Date : 08/12/2004 Repair Order Number : 027362 Odometer Reading : 30031 miles
PO BOX 243
Site Code : 32439
08/20/2004 510 01 # F1007 - UNIVERSAL JOINT, REAR PROPELLER SHAFT - BOTH - REPLACE 12476135 - JOINT KIT N
Repair Order Date : 11/20/2002 Repair Order Number : 024647 Odometer Reading : 11 miles
PO BOX 243
Site Code : 32439
12/03/2002 331 01 # A0110 - FINESSE SAND AND BUFF N/A N
Repair Order Date : 10/08/2002 Repair Order Number : A79102 Odometer Reading : 0 miles
PO BOX 243
Site Code : 32439
10/15/2002 317 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
Vehicle Build
Help
VIN 2GCEK19T731179102
VEHICLE BUILD
Gross Vehicle Weight Rating : 2906 kg (6408 lb) Order Number : FQMNNB
Build Date : 10/08/2002 Build Plant : 23153
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AG1 - SIX-WAY POWER DRIVER SEAT AG2 - 6-WAY POWER DRIVER & PASS SEATS
AJ1 - DEEP TINTED GLASS AL0 - SENSOR INDICATOR INFLATABLE RESTRAINT FRT PASS
AM7 - FOLDING REAR SEAT AN3 - FRONT BUCKETS WITH POWER ADJ.
AU0 - KEYLESS REMOTE DOOR LOCK AU3 - POWER DOOR LOCK SYSTEM
A31 - POWER WINDOWS B30 - WHEELHOUSING & FLOOR CARPETING
B32 - FRONT COLOR-KEYED FLOOR MATS B33 - REAR COLOR KEYED FLOOR MATS
B71 - WHEEL OPENING FLARES B85 - BRIGHT BODY SIDE MOLDINGS
CJ2 - AIR COND., DUAL ZONE AUTOMATIC C49 - ELECTRIC REAR WINDOW DEFOGGER
C7H - 6,400 LB GVW RATING DF5 - ISRV MIRROR W/COMPASS & TEMP
DK7 - INTERIOR CUSTOM ROOF CONSOLE DL3 - OSRV MIRROR W/DRIVER SIDE AUTO DIMMING, PWR FOLD & ADJ, HEAT, TURN SIGNAL
DT4 - ASHTRAY MUFFIN D07 - CUSTOM FRONT FLOOR CONSOLE
EVA - EVAP EMISSION REQUIREMENT E63 - FLEETSIDE BODY
FK2 - TORSION BAR SPRING ADJUSTMENT FK3 - TORSION BAR SPRING ADJUSTMENT
GT4 - REAR AXLE - 3.73 RATIO G80 - LOCKING DIFFERENTIAL-REAR AXLE
JC3 - 4 WHEEL POWER DISC BRAKES KNP - HD AUX TRANSMISSION COOLING SYS
KUP - THROTTLE CONTROL ELECTRONIC K34 - CRUISE CONTROL
K47 - HIGH CAPACITY AIR CLEANER K68 - 105 AMP DELCOTRON GENERATOR
LM7 - VORTEC 5300 V8 SFI GAS ENGINE M30 - 4-SPD AUTOMATIC TRANSMISSION
NC8 - CALIFORNIA EMISSIONS ULEV NE1 - MA / ME EMISSIONS
NP5 - LEATHER WRAPPED STEERING WHEEL NP8 - AUTOTRAC ACTIVE TRANSFER CASE
NZZ - OFF ROAD - SKID PLATES OSG - OSHAWA ASSEMBLY
PDD - COLOR-KEYED CARPET PDL - OFF ROAD PACKAGE * OFF ROAD SUSPENSION * P265/75R16 AT WOL TIRES * FRONT FOG LAMPS * ALUMINUM WHEELS
PF9 - ALUMINUM WHEELS QGD - P265/75R16-114S ALT WOL TIRES
SAF - SPARE TIRE LOCK SLM - STOCK ORDERS
TR3 - CHROME GRILLE T96 - FRONT FOG LAMPS
UB1 - AM/FM STEREO W/CD & CASSETTE UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL 1 YR SAFE & SOUND PLAN
UK3 - REDUNDANT RADIO CONTROLS UQ7 - BOSE SPEAKER SYSTEM
VB3 - CHROME REAR STEP BUMPER VG3 - FRONT DELUXE CHROMED BUMPER
VK3 - FRONT LICENSE PLATE MOUNT VR4 - WEIGHT DISTRIB. PLATFORM HITCH
VXS - COMPLETE VEHICLE LABEL V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGD - P265/75R16-114S ALT WOL TIRES X88 - CHEVROLET CONVERSION
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX YD6 - BASE REAR SPRING
YE9 - SILVERADO YGD - P265/75R16-114S ALT WOL TIRES
ZGD - P265/75R16-114S ALT WOL TIRES ZY1 - SOLID PAINT
Z71 - Z71 EQUIPMENT PACKAGE Z82 - HEAVY DUTY TRAILERING EQUIPMENT
1SC - LT DECOR INCLUDES: * AIR COND, DUAL ZONE AUTOMATIC * ISRV MIRROR W/COMPASS & TEMP * OSRV MIRRORS W/DRIVER SIDE AUTO DIMMING, PWR FOLD & ADJ. HEAT, TILT & TURN SIGNAL * REAR WINDOW DEFOGGER * DEEP TINT GLASS * AUTOTRAC ACTIVE TRANSFER CASE * FRONT FOG LAMPS * AM/FM STEREO W/6-DISC CD CHANGER & BOSE SPEAKER SYSTEM * ELECTRONIC SPEED CONTROL * POWER LOCKS & WINDOWS * REMOTE KEYLESS ENTRY WITH CONTENT THEFT ALARM * LEATHER WRAPPED STEERING WHL * ALUMINUM WHEELS * BODY SIDE MOLDINGS * ONSTAR COMMUNICATION SYSTEM INCL 1 YR SAFE & SOUND PLAN * REDUNDANT RADIO CONTROLS 1SZ - PREFERRED EQUIPMENT SAVINGS
6YH - COMPONENT FRT LH COMPUTER SEL 62U - DK GRAY METALLIC
69I - DK PEWTER INTERIOR TRIM 692 - DARK CHARCOAL TRIM
7YH - COMPONENT FRT RH COMPUTER SEL
Vehicle Component
Help
Vehicle Component
Component Code : 10 - ENGINE ASSEMBLY
Source Plant : K - GM OF CANADA, LTD. ST. CATHARINES, ONTARIO
Part/Num Broadcast : FJB Traceability : 022801013
Date Scanned : 10/08/2002 Time Scanned : 11.59.00 Scan Station : 04
Component Code : 35 - STEERING COLUMN - SIR SYSTEM
Source Plant : S - SAGINAW DIVISION SAGINAW,MI
Part/Num Broadcast : WJY Traceability : 543302772
Date Scanned : 10/08/2002 Time Scanned : 09.41.00 Scan Station : 10
Component Code : 50 - INSTRUMENT CLUSTER
Source Plant : 3
Part/Num Broadcast : DSX Traceability : DSX
Date Scanned : N/A Time Scanned : N/A Scan Station : N/A
Component Code : 60 - TRANSFER CASE (4 WHEEL DRIVE)
Source Plant : N
Part/Num Broadcast : WN Traceability : 0AQ689060
Component Code : 61 - TRANSMISSION
Source Plant : Y - HYDRAMATIC TOLEDO, OHIO
Part/Num Broadcast : 3KCD Traceability : 35185998
Component Code : 63 - FRONT AXLE/FRONT CRADLE WITH FRONT HUB ASSEMBLIES
Source Plant : G
Part/Num Broadcast : UL2 Traceability : C098467
Date Scanned : 10/08/2002 Time Scanned : 13.09.00 Scan Station : 05
Component Code : 65 - REAR AXLE ASSEMBLY
Source Plant : G - SAGINAW DETROIT, MICHIGAN
Part/Num Broadcast : TL4 Traceability : 064302
Date Scanned : 10/08/2002 Time Scanned : 13.05.00 Scan Station : 07
Component Code : 86 - ELECTRONIC CONTROL MODULE (ECM)
Source Plant : 9
Part/Num Broadcast : YCTJ Traceability : 22278B48G
Date Scanned : 10/08/2002 Time Scanned : 16.03.00 Scan Station : 01
Component Code : 87 - BODY CONTROL MODULE
Source Plant : M
Part/Num Broadcast : 4169 Traceability : 2227589WW
Component Code : 92 - BRAKE PRESSURE MODULATOR VALVE ASSEMBLY
Source Plant : K - KELSEY-HAYES JASPER, INDIANA
Part/Num Broadcast : 2718 Traceability : 00165838
Date Scanned : 10/08/2002 Time Scanned : 12.56.00 Scan Station : 09
Component Code : AB - IR-MODULE ASM-INFLATOR
Source Plant : Q - RIMIR MATAMORS MEXICO
Part/Num Broadcast : 5374 Traceability : 9CEGD3C
Date Scanned : 10/08/2002 Time Scanned : 13.56.00 Scan Station : 11
Component Code : AH - IR-SENSOR ASM-LEFT
Source Plant : V - DELCO ELECTRONICS REYNOSA MEXICO
Part/Num Broadcast : 7506 Traceability : 2271H92P9
Component Code : AJ - IR-SENSOR ASM-RIGHT
Part/Num Broadcast : 7506 Traceability : 2271H92P8
Component Code : AL - IR-MODULE ASM-I/P
Source Plant : M - MORTON-THIOKOL
Part/Num Broadcast : 2351 Traceability : 8WEIU40
Date Scanned : 10/08/2002 Time Scanned : 09.41.00 Scan Station : 01
Component Code : AS - SENSING DIAGNOSTIC MODULE
Source Plant : K - DELCO ELECTRONICS KOKOMO,IN
Part/Num Broadcast : 2446 Traceability : 122774K7H
Component Code : BX
Source Plant : N/A
Part/Num Broadcast : N/A Traceability : N/A
Date Scanned : N/A Time Scanned : N/A Scan Station : 06
Component Code : CB - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 199 Traceability : 0650935
Date Scanned : 10/02/2002 Time Scanned : 23.03.00 Scan Station : N/A
Component Code : CP - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 133 Traceability : 4078852
Date Scanned : 10/08/2002 Time Scanned : 07.46.00 Scan Station : N/A
Help
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 11/20/2002 Delivery Type : 010 - RETAIL/INDIVIDUAL Delivered Odometer : 140 miles
PO BOX 243
(781) 828-3800
Delivery Selling Source : 13 - CHEVROLET
Delivery Site Code : 32439
Dealer Information
Help
INVOICE INFORMATION
Invoice Date : 10/08/2002
Site Address : JOE DOWNEY CHEVROLET, INC.
PO BOX 243
Site Code : 32439
SHIP-TO INFORMATION
Ship-To Date : N/A
PO BOX 243
Site Code : 32439
I had the same problem. I emailed them, and they replied 24 hour afterwards via email and telephone to let me know that they had processed my request. So, give them a call or send them and email, and they will get on it pretty quickly.
-Al
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 885 Guests (See full list)
