Spark Plug Gaps
I just installed new plugs on my 2000 2500 with 6.0 and the tech at parts store told me to gap them at 040 but when I checked my manual it states to gap them at 060? What does this mean? Do I have to remove the plugs and re gap them? What harm if I dont?
when GM switched spark plugs to iridiums after your truck was built they changed the recommended gap for them to .040.
Not a big deal at all, if you have any problems with how it's running you could try re-gapping. But, I would leave it a lone. Shouldn't make much of a difference.
Thank you for info, I guess alot of things have changed since 2000.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
