Autoride Compressor Runs Frequently
mitchc23
93k miles. Recently the autoride compressor has gotten more loud (buzzing) and cycles on frequently. I do not notice any level changes with the vehicle. Sometimes as fast as every 3 or 4 minutes. Any idea as to why? How best to address?
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,344 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
